Another bar riser Q
hoffam19
The UP
Are 97' MM cables compatible with a 97' XTC 500?
If so, what is the max size I can go with MM cables?
Im running a 2" right now and the oil cable is damn near to short and the throttle cable it pretty tight too. Im looking to go 2 more inches for a total of 4".
Finaly, do I also need a longer brake line? That looks kinda tight too.
I have a 97 SX 600 & I have read that you can get 2" riserughts but mine will not! I used SS 3/8 couplings that are 1" , bought lo!nger bolts & worked perfect
