srxfastervmax4
HAS anyone had oil spraying out of there power valves area? I got spots of oil in front of engine, top of cyl heads. Seems to be coming out around cable were it goes in to the valve.
ecopter
It's probably a good idea to change the o-rings. Sometimes it will do that when the engine hasn't been run in awhile, and once it warms up and you use it a lot, it seems to seal itself up. Normally, you'll get that spray on the bottom of the valve and it drips down on the exhaust manifold. Just change the rings and possibly the thin metal gaskets.
Jon
Jon
jon is right on the money we had to do this to my brother's srx 600
srxfastervmax4
How tough is it to change the o-ring? Should I change all the seals and gaskets inside there?
