I forgot what the distance is how far should you put the probes on the pipes on an 01 srx?Thank's
bluehammer
Should be 7-8" from the center of the piston or center of spark plug hole.
SRXSRULE
- May 2, 2003
I ran mine 9" from the exhaust side of the piston skirt. The distance dont make a huge diff because you still have to match temps to wash and plug color to know your limits. At 9" with coated pistons my limit was 1375* at 1400 it was done
===SRXSRULE===
