Rolling chain case
pro116
Lifetime VIP Member
Appleton,WI
what does it do besides give you more clearance.Is that the way to go or just get 8t drivers?
rolling your chain case is a night a day differance if you ride powder or into hill climbing. If you just trail ride it is not worth it
Def. worth it if you ride any powder..You don't trap so much air with the big track you free up track hp with the bigger drivers and the approach angle for attacking the hills is way better(every sled i've had has had a tunnel)
I'M NEW TO THIS SO I HOPE I'M DOING THIS RIGHT. NORTHERN LITES IN COLUMBIA FALLS, MT. MAKES ROLLED CHAIN CASES. YOU CAN CONTACT DENNIS AT 406-892-0240. I HAVE MINE THERE NOW SO CAN'T TELL YOU HOW WELL IT WORKS BUT ALL THE INFO SAYS IT SHOULD. HOPE THIS HELPED.
Hartman Inc. sells a kit to do this. Mountain Performance sells the parts to do this. Ekholm has kits also. Night and day. I've done the MPI kit .
