blueblooded
How do you take the sway bar off a 04 viper s? I want to replace mine and im not sure how it comes out.
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
drill out the bracket where the sway bar goes through the tunnel on each side, and remove the sway bar for the trailing arm.
blueblooded
2ooosrx said:drill out the bracket where the sway bar goes through the tunnel on each side, and remove the sway bar for the trailing arm.
Ok thanks,i wasnt sure if the sway bar would slide out if i took the end caps off.
Millinocket Rocket
blueblooded-- just curious which sway bar you're putting on and what it really does for handling?- i've been thinking about one myself- if it helpsblueblooded said:How do you take the sway bar off a 04 viper s? I want to replace mine and im not sure how it comes out.
blueblooded
I was in a accident last year with my sled and i replaced everything but the sway bar,i think the sway bar is slightly bent so im going to put on a new oem sway bar.
Millinocket Rocket
oh- sorry to hear. i thought you might be upgrading
