benderxtc700
There seems to be alot of clutching info on sx,sxr,srx, but not much on the xtc. I've only been sledn for 1 season so dont know alot, but this site is awesome for newbies like myself. would any of these setups be the same for an xtc?
My sled has bender tripple pipes and soon to have a ripsaw. It runs great, but I think it would run even better with some clutch work. Would the bender kit be my best bet or does anybody have a custom set-up for the xtc?
do some searches on 700sx, same motor as yours...CP
Get a 51/43 helix & add enuff weight in the primary so sled will run 82-8400 rpm at wide open throttle. I clutched a lot of xt-xtc-sx-r,s & they all ran very similar with different parts as long as rpm,s were in this range.
benderxtc700
cool thanks guys
xsivhp
Mini
xsivhp's Avatar
Member #: 2419
My Sled: 04 VIPER S
Default
Turk, I need some help with the same sled, all stock though. Can I gear down a reverse equipped sled? Do the shims go in the prinary or secondary? And is 142.5 jetting good down to what temp?
Thanks tons.
xsivhp
_____________
xsivhp's Avatar
Member #: 2419
My Sled: 04 VIPER S
Default
Thanks tons.
xsivhp
_____________
Shims go in the primary. Stock gearing in the reverse is fine..it is allready geared down.142.5 is good to about -30.
xsivhp
So if I do the sx700 trail clutch set up and peel the head gasket, (and don't worry about the gearing) it should wake it up considerably?
It's my dad's xtc, and I'd like it to run pretty close with a stock 04 viper if possible (which I think should be possible.)
What do you guys think?
