VDO Extreme tach will it work on 2000 srx
srxreid
mn.
Does anybodie know if a vdo tach with recall will work on the 18 pole mag.called vdo tech he wasnt sure. THANX sled is a 2000 srx.
Sure will. IF I recall, set the dip switches to 1,2,3, ON and 4 off. cant recall what wire to pull off but SRXSPEC can tell ya. ===SRXSRULE===
Yes it will work. 1,2,3 on and 4 off, then red to power, black to chassis ground then to negative, and green wire to the yellow/black wire anywhere in the harness (it does run right up to the headlight pod).
