deekersrx700
Might go grass dragging soon, who's got the best set-up? Clutching, gearing, jetting?? Heel clickers? 8bu-00s? 2001 SRX700 -- 500-660ft whatever COSDRA is?
Deek
Deek
*99sRx700*
if Junior ever gets back on, he has a good setup for yah im sure
Srxspec
Your #1 performance shop!
-40-10Y Heel Clickers with an engagement notch ground in them, engagement should be around 4900 rpm.
-Red Heel Clicker spring
-15.6mm rollers
-6-grams heel
-0-mid
-7-grams tip
-45/41 advant-edge helix
-silver secondary spring @ 70-90* (depending on conditions)
-20/39 gearing
-K&N Air Filters RU-2750
-Rear spring set with 1" of thread showing
-FRA in the stiffest setting
-Transfer rods adjusted for traction (preferred less than 1/16" of gap on top side and locked solid when on good traction)
-Limiter Straps set as needed (you want 2-3" of ski lift off the line and skis barely in the air going down the track).
-Front spring in the rear suspension tightened to the max
Setup from the 2nd place SRX Hay Days 2000 and NSRA Tri-State Triple Crown winner in 2001 (won events at Princeton MN, Grayslake IL, and Wausau WI).
-15.6mm rollers
-6-grams heel
-0-mid
-7-grams tip
-20/39 gearing
*99sRx700*
that guy right there knows his stuff!!!!! Bet its a killer setup
deekersrx700
Thanks a million spec, we'll see if the old girl can get-r-done. What is the "FRA"?
Deek
Deek
Srxspec
The FRA adjuster is on the front of the rear shock. There is three positions, the lowest is soft and the top is the stiffest.
srxbully
got any for the heavy hitters & how would a 56-44 helix do?
Srxspec
Nothing for heavy hitters. Tried them and they were slower, threw the notes away after that. If I still had a SRX setup for grass I'd try the new Super Tips, I think you could be even faster then. As far as the 56/44 you're gonna need less heel weight then.
YAMMIEGOD3:16
ALLAN, YOU HAVE ALWAYS TALKED HIGHLY OF THESE HEEL CLICKERS. I KNOW YOU TRYED 8BU-00,s. NOW LET ME ASK YA TWO QUESTIONS, IS THAT A YAMAHA SILVER SECONDARY SPRING YOU USED AND I ASSUME THERE ARE THREE TUNEING HOLES ON THESE WEIGHTS BECAUSE YOUR LEAVEING MIDDLE EMPTIE. SEEMS YOU COULD RUN MORE HELIX THAN A 45-41. SOONER OR LATTER I HAVE TO TRY THIS IN MY 2000 SRX. 696 TOLD ME THIS WORKS NICE TOO, HELL I WOULD LIKE TO TRY THEM IN A 800 VMAX. WHAT YA GOT YOU CAN SELL !! 3:16 (tony)
Srxspec
Tony, the silver is just a factory Yamaha secondary spring. The heel clicker has an adjustment point in the "heel" of the weight, then one in the middle and one on the tip of the weight where you can add or remove fasteners. The 8BU's are also a nice weight and work well, I just hated pounding rivets in and out to make adjustments to the weights! The 45-41 Advant-Edge helix will shift like a 49/45 or a 50/45 when comparing it to a Micro Belmont, Maxx Perf, Bender, Dalton, etc. Let me do some digging through the shop bins. I know I have some heel clicker sets around yet that I'll let go cheap.
yamaholic22
Allen did you notice real high clutch temps when running clickers?
Srxspec
Clutch temp's were in the 120-130 range if memory serves me correctly. On today's 4-strokes we have clutch temps down to 100-110* using the Super Tip weights. I know we could've went faster with the Super Tip weights in our 01 SRX, just don't have the sled anymore!
deekersrx700
Spec, are the supertip weights the newest heelclickers?
Deek
Deek
Srxspec
No, the Super Tip weights are a completely different company. The Super Tips are made by Supreme Tool Machine out of MI. www.supremetoolinc.com
deekersrx700
What makes them better you think? Is it the profile? Have you tried the 40-20 heelclickers? Just curious as to how they work.
Deek
Deek
Srxspec
Profile and more adjustability. I've never even heard of 40-20 heel clickers? Are you talking the weights with the pivoting shoulder?
deekersrx700
Yes on supertorquers site they call them 40-20?
yamaholic22
yea everytime i have used clickers i have noticed significantly elevated clutch temperatures no matter what you do. Too much squeeze force maybe to get the fast upshift creating friction being lost as heat energy?
what make sthe supertips much different then heavy hitters, they look close
Srxspec
The heel mass of the weight, the location of tuning spots on the weight, and slight differences in the profile = better acceleration, top end, and back shifting in my testing.
