when you remove your spindles. and set them down where the ski bolt goes in .should there be any angle to the shaft at all .these are off a 98 srx thanks
If I understand your question correctly, most of the Yamaha spindles have the ski mount plate square with the end of the spindle shaft. I would say then that there should not be any angle.
