The_BeaverBanker
Hmmm seen this on ebay..and ..good buy or not?
http://cgi.ebay.com/ebaymotors/Yama...wItemQQcategoryZ100456QQitemZ4578189282QQrdZ1
maxdlx
VIP Lifetime Member
Seems cheap if you can use it. It is worded funny as to wheter the case goes with or you must buy seperatly. That would be my only ? Maxdlx
montynormand
The way its worded, it seems to me like the case is not included
*99sRx700*
case is included, because will not seperate, so i would take that as case is included, and it is in the picture, so it has to go, otherwise tehre would be a xxx in picture not included.
toydoc
"new pistons need to be bought"
What piston does a 650 Exciter take and who if anyone has them?
In PSI's catalog shows it at 115.7HP not 130HP.
Pistons for 650 Exciter reed engine 77.0, 77.5, 78.0mm.
The pipes are worth $100 or so.
03viperguy
ended early due to an error in the listing............guess toydoc must know what he is talking about
mark the shark
toydoc knows what he's talking about.
Shark
Shark
800
You need the cases for that set up because they are modded for the mono cyl assy. That thing used a watercraft piston, no biggie to get. The big problem is they never made 130hp. PSI had casting problems with alot of them and ports didn't line up well. I think we had one that made like 125 but most were in the high teens. Did make a bunch of torque and was fun to ride. Those pipes work well on a stock EX and even better on an SX.
THat was made when PSI was making Genesis everything, that was the 650 Genesis EX and he made a very billet head that I didn't see in the pic. Someone paid over 3K for that thing in the day...........
