SRX MAINE
Hi, I was wondering if anyone has successfully put reverse in a SRX700?
If so, how?
If so, how?
shortstop20
- Mar 6, 2005
- Stickney, South Dakota
- www.snowmobilefanatics.net
Yes it is possible. Go to www.totallyamaha.com then go to the tech pages. Click "Snowmobile" then click Chassis/Rear suspension and Drive". It's in there, 10th from the top. All instructions are there.
I've done it. Well worth the effort. It's really not to hard.Here's another link,
http://www.totallyamaha.net/forums/showthread.php?t=2380&highlight=reverse
SRX MAINE
Before moving to the next step, you will need a new HYVO 3/4 top gear and a HYVO 3/4 chain to mate with the new HYVO 39T gear provided with the kit. (This kit will not work with the stock 15W gear and chain on 98' & 99' SRX's, ...00' and above use HYVO components). (SEE PICS)
What is the diff. between a HYVO and 15W gear?
I have an 01 srx. will the standard viper kit work alone?
yes it will , the 01 srx has hyvo gears allready.
SRX MAINE
Hi again, I noticed that the viper kit that the tech forum suggest has a 39 tooth lower
gear. My SRX has a 38t lower gear.
How much does this matter?
Do I have to change the top gear too?
Also, what year Viper kit, there are two different ones
wild child
i have a 98 mountain srx and ive done it, i forget which kit i bought and mod., i ripped the drive chain in half once the first year i had it because the chain was 2 links skinnier, but i replaced it and havent had a prob. since.
OZ
yes but...
SRX MAINE said:Hi again, I noticed that the viper kit that the tech forum suggest has a 39 tooth lower
Either kit should fit, ...if you want to maintain your original gear ratio, change your top gear based on what bottom gear you end up with on your reverse kit (usually 39T).
http://maxxperf.com/gearingchart.htm
SRX MAINE
OK cool, I think I got it.
Want to double check for me?
I come up with 04 Viper Kit 8EK-W4759-10-00
This should have everything I need, including a 38t HYVO bottom gear, Right?
Thanks in advance
Bob
Thanks in advance
Bob
