Went out tonight to put my oversize wheels on, and there is a big puddle of fuel under the sled. I removed the air box and it is wett all around the pump and all of the lines. If you touch the pto cylinder line it leaks gas on both ends. the other 2 if you barely touch them near the ends they leak. Never had a pump go bad, but would it leak somewhere too. I am going to try and replace the fuel lines with regular black fuel lines, instead of the chinsy green stuff. Has anyone else had this problem, or replaced the lines with regular black auto fuel lines. Snow is a comming and I can't get a pump, so I hope the fuel lines fix it. Any and all help appreciated. Maxdlx
Damn
Redid fuel lines, and still leaking fuel. it is coming out of the pump stone filter. Anyone ever cover that up with silicone. Maxdlx
bigbigrichie
try denniskirk they have rebuild kits
Thanks but
Found out if you have a base gasket go bad, it will make the pump act up, lean out the motor and ruin all 3 cylinders. Oh well. maxdlx
