mid range cleanup
riverman
Hi folks. Whats the best way to clean up the mid range burgle and overload on a 99 700 triple? Reeds? Lower the needle? Jetting? Thanks for the help. Riverman
you really need to either notch your reeds or put spacers.
The tech page will show you how to notch the reed.
Good Luck.
Drop the needles 1/2 if it is a 700 single pipe engine. Jetting is a little conservative.
