SRX Long Travel Help
BadAzzSRX
Southern Maine
Newby needs help!
I am going to long travel the front and rear of my 99 SRX 700. I plan to use Ohlin clickers with extension brackets on the front and revalved Viper shocks on the rear. I know I have to swap out the limiter strap, but is there anything else I need to do? I know the info is on this forum somewhere, but I can't find it using Search. A link to the threads or any help would be appreciated.
TIA
BadAzzSRX
You will also need different spacers for the transfer rods. If you call Maximum perf. they will send you the correct ones to use.. That's all you need on the 99.
