2 questions
norwegian
Well-known member
norway
1) Will a artic cat "attack 20" track (141*1,5*15) fit a 2001 mm if you get the 3" pitch drivers?
2) What is that flat rear heat exchanger found on some warriors (installed after purchase) called? Kind of like the 2001 mm rear heat exchanger just 3 times as large.. Anyone know what I am talking about?
Is the 01mm a 141 stock? I can't remember myself. If so, 7 tooth 3.0 drivers should be close enough to the stock 8 tooth 2.52, and I would try Mountain Perf for a nice flat heat exchanger and if I can find the part # I will post it for ya.
Do these two have the same diameter? That part # would be great
thanks
