I have had this problem ever since I installed a clutch kit at 1,000 miles..
When the sled is warm and I come to a stop the rpms want to stay at 4100-4200 rpms for 20-30 seconds and then will slowly go down to normal.....
I have cleaned my carbs adjusted the fuel screw one turn out past specs...
and then put them back into specs 1 7/8 and I still have the problem...
My throttle cable has plenty of slack and my choke lever is fine....
When I hit the throttle fasst when it is idling high it will go down faster to normal idle.
I have adjusted my idle to no end going between 1800 down to 1400 rpms with no better results....
The sled runs great otherwise but this is annoying!!!
Any help would be very much appreciated........
