SRX Can, good or bad.
gwinnraptor
Gwinn, MI
I Just got a DG Can from a guy on here for my SRX, does anyone know will this improve HP greatly, not alot?
Also, in time could this can hurt my sled?
thanks
whats the reason that everyone does the aftermarket cans anyways then?
weight? is it really that big of a difference?
thanks again.
The old Power Inc cans will gain 1 hp but other then that, I have seen the same thing on most cans. Either no gane or just a lot of noise.
Yea most people put them on for the bitchin music coming from the can, and weight savings.
If it does not cause you to loose power then the weight savings should be benificial. I have a Bender can on my SXR and I like it. It is coming off soon as I purchased tripples.
Real world test i did same day back to back runs 2ea way .I went to the track 1000 ft ice ran with stock can , then ran with bender can 1 mph slower with the bender each time.bender can is like 12lb less also. just my results.
Less restriction does not necessarily mean more power, because the acoustics of the tuned exhaust is changed. Basically, Yamaha took their good sweet time with the stock exhaust on the srx's, you will be EXTREMELY hard pressed to find an exhaust setup that works better than stock on a stock engine. None of the aftermarkets can do it in full exhaust systems for the srx, a silencer doesn't do any better.
Yes, the stock SRX exhaust is exceptionally well tuned for the stock motor. Even if you find a way to gain hp, it will likely not be the same power curve. There goes your clutching setup, so get ready to tune.
my father has stingers for his SRX, and actually took them off last year, because they are so darn loud, and would constantly turn heads. when he had them on, i never had to turn around to see if he was still behind me!
