unclejessie1967
- Jan 26, 2004
My machine keeps blowing headlights? It was a every couple rides it would blow, then last night as i was riding all the lights on the whole sled blew?? I replaced them and rode for 4 hours and no problems. And also when u touch the break lever the headlight will dim. Any idea where to look for a problem? Bad ground? short? I have no idea where to start.
Eric
Eric
Blue Devil
sounds like your voltage regulator.
Phazer
Yes...sounds like the voltage regulator. Located just above your left toes inside the engine compartment, behind the secondary. I have 3 Phazers and all of them will dim the lights when you put the brake on.
unclejessie1967
- Jan 26, 2004
Where should i look for one? Any online parts resources for older yamaha parts?
Eric
Eric
Blue Devil
check with your local dealer or aftermarket suppier .If you are in Canada royaldistributing.com 29.95
