Lightning Pro Roller Secondary
Harvey
upstate NY
Any of you guys running one of these?Does it improve pulling power,top speed,ect.or is it just for improving back shift?I like the idea of being able to use a standard helix in it,seeing as I have quite a few different ones to try.thanks-Harvey
No one uses one of these?What about other brands of roller secondaries,any opinions?-Thanks-Harvey
Roller secondary
the RX3 roller secondary is good
made by the same guy that invented the roller rooster the RX3 is said to be three times better then the gen 2 roller rooster
call Rick at ADVANT-EDGE MOTORSPORT he's the inventer of this clutch
www.advant-edgemotorsport.com
phone 905-458-7226 fax 905-458-9266
Harvey,
I've used the Ligthing Pro secondary for a couple of years now and it's still working just fine. The shifting is top notch and yes I have tried several different helixes and spring combos in my 02 Viper. I don't think that it does much for top end, in itself, but the shifting is good and acceleration is great. I think that it probable as good as most out there.
Hope the info helps ya.
yamaman,thanks for the reply,so the accelleration was imroved useing the roller secondary?thanks-Harvey
