Triple X
Would a 700 top end bolt on to a 600cc Venom. That would be the ulitmate sleeper. throw a set of pipes on it, do the head gasket and reed spacer. You would have the horsepower plus the reliablity.
Triple X said:So i could swap the top end, use the 33mm carbs and the cdi from the Venom or should i use the cdi from a SXR 700 as long as it is the 300 watt. Thanks for the help.
