auji700triple
Ok, im Very confused.. One of my Friends are trying to tell me that i will Do alot better outa the hole(bottem end) with a 21 gear than a 22 gear(ment for Speed) i am very confused because alot of people been telling me to run the 22 for out the hole , Note that i have a 144 1.5 track... Help is very appreaticed here.. thank you!!
Cuzino19
Normally a 21 tooth gear would be better for acceleration but I think that its because you have such a big and long track. Thats prolly why the 22 is better than 21 in that situation.
yamaholic22
21 will be better than the 22 out of the hole, but will have less top end holding everything else constant.
nodoo_s
maybe your friend is thinking you will have less track spin with the higher gear giving you a little better traction
auji700triple
Alright that Helps alot! thanks, but i alrady have the 22 installed and i will giver her a go and see if theres much of a difference and what not!
THKSNOW
We went to the 21 in our stock Vipers. Lost a little on top, but gained a TON out of the hole. With a deeper lug longer track, I would think the 21 would make a HUGE difference for you. Seems to me it would take a lot more to get the big deep track turning. Am I all Snow?
auji700triple
Oh, i was confused about the 22 being bigger than the 21 hence Losing speed, but better out of the hole.. i guess not.. but i should get outa the hole just fine dont ya think? theres more to this than just stock motor.. hehe
yamvip
I was wonder the same about changing teeth in my viper,corner to corner is it worth it?
THKSNOW
YES -It made a HUGE difference in our Vipers and only cost $20-30 to find out for yourself.
yamvip
Would that mess with the clutching at all?And would I need a shorter chain??
richierich
if you decide you want a 21.i have some oem ones brand new laying here.$35 shipped.i have 2 left.
yamvip
would I need to replace the chain,its the original???
richierich
no not with a 21.
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
I sent you a P.M. to save you some money.
richierich
yamvip.i also forgot i have a brand new epi 21 for $25 shipped
THKSNOW
This was a very easy mod to do, no need to change the chain. The hardest part is messing with the chain case oil (which should be changed at least once a year anyway). It's a great time to inspect chain etc. Just make sure to use some locktite on the sprocket nuts when you put it back together. Don't tell your riding friends that you did it. Just remember not to SMILE too much when you line them up for the impromto drag race... I was laughin my azz off after I beat my son out of the hole (both Vipers and he was pizzed off) for the third time...
redsnake3
hey AJ,
if you need any parts Bruce is a good guy to deal with.
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
AJ, your PM box is full! Tried to send you something.
*99sRx700*
matt, I just told Aj to go empty it, give him a few minutes, then send again
03viperguy
does anything else need to be changed clutching wise?
