I see the dipstick to check the oil but I do not see the plug to drain it. Do I have to remove the exhaust to have access? Any advise is apprecited. Thanks ( 2000 Venture 600 triple )
It is on the inside of the tunnel, right behind the chaincase. Takes a 12mm wrench. Maxdlx
n2oiroc
its in the tunnel. look under the sled on the right side. there is a 12mm bolt by the chaincase. thats it.
edit, beat by maxdlx
