Anyone Try 2000-2002 Srx Jetting On A Piped Viper??
n2oiroc
p.m. betheviper, i think i remember a few posts a while back from him about that.
aftermarket pipes wont run pilots that lean. my slp ran 47.5 and better on 50. my sled with srx pipes even with the viper box ran 40pilots when i switch to the srx box sled runs and idles the same with the 40 pilots. im sure it is pipe design. as for mains the timing is the problem, with the srx box i can run 156, with viper box have to run 165 to be safe. this is with the srx pipes. the box makes this much differecne
with venting out of box i ran 150 mains and 40 pilots with srx hardware in carbs.
BETHEVIPER said:aftermarket pipes wont run pilots that lean. my slp ran 47.5 and better on 50. my sled with srx pipes even with the viper box ran 40pilots when i switch to the srx box sled runs and idles the same with the 40 pilots. im sure it is pipe design. as for mains the timing is the problem, with the srx box i can run 152, with viper box have to run 165 to be safe. this is with the srx pipes. the box makes this much differecne
thanks!!
