yamyrider
you cant just raise that sled to make it look as high as newer sleds.
The goemetry behind the sled was designed to be low and some newer sleds have the rider forward design and higher sitting position. if you take your sled and just make it higher you will loose performance in the trails since you will not be able to corner the same anymore. There are some guys on here that have raised their sled a little hopefully one of them will buz in with some how to's....good luck.
