exhaust wrap
yamyrider
Northern Ontario
Hi Guys,
Would it be safe to use the wrap where the pipes touch together.
I am trying to keep them from rubbing and wearing.
I do not want to wrap the entire pipe but only a few spots.
I have AAen and I know they are thin and dont want wear through.
Thanks.
thats not a bad idea, and you're right the aaen's are REAL thin, and will wear through if they touch anywhere with time. Go ahead and put some wrap in the spots where they touch. Another spot you might want to watch out for is the intake louvers on the mag side of the hood. (the double intakes on the top right of the hood when sitting on the sled). The aaen's pretty much touch the bottom of the hood there and will probably bubble the paint on the louver if you don't wrap the pipe or put something on the bottom of the hood there.
