SRX MAINE
Is best for use on the different areas
Ex. Skid rail bolts, radius rods, drive gears, power valves, ect.
I've been using Pro Black for a while on lawn equipment,
but I like to hear your thoughts on what you use on your yamaha
Red On The Suspension Parts Is What I Use
What color of loc-tite to use on helix on a viper?
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
For the helixes, loctite is not at all necessary. But for majority of the sled, if you are going to loctite, use blue. It is temporary loc tite so if you intend to take the bolt out again, it will not be as difficult to get out as red. If you are worried about your bolts coming out, you can use red if you would like. Either will do the trick.
