Clutching & Gearing for drags
O's srx
VIP Lifetime Member
Cobourg, Ontario
Anyone know what gearing, clutch weights, springs and helix i should run for a 500" drag race. On grass and snow while staying in the stock division.
P.S. I'm currently running heel clickers in the primary 2.8-3.3-4.3 w/(red spring) and a 45-37 helix w/red spring @ stock preload on the trail. :?
if this is for an srx....then this setup is awesome.......8bu's with 4.5 on tip 2.4 in middle with a hauck orange spring or a dalton green/black and set your gears at stock minus 2 teeth on top.........engagement should be at 4400 and top 8400........hold on cuz your holeshot will be great and even greater dpending on ur track...
