Hey ModMMax
herb
Saskatchewan
Looking through those instructions i see that i need a spacer on the driveshaft (speedo side) because the stock tunnel has a 4 inch hole and the new one does not.I do not have this spacer.Any suggestions.How much for a set of those slick footrest supports you made?I will get your stuff back to you this weekend.THANX.
Driveshaft spacer looked like a 1/8" washer. We can pull mine out and duplicate it. The footrest supports were made from aluminum 3" by 3" I-beam. I cut a wedge out of the web and tig welded the 2 pieces back together. Don't have anymore I-beam. I think that piece came out of a cattle liner frame. We'll think of something.
