help removing sway bar
You can drill out the rivets that hold the guides in place that the sway bar goes through, and slide it out. A couple of the rivets are hard to get at, but can be done.
The bottom plastic body is covering two of the rivets so i dont think i can drill them out unless i remove the body.Nothings ever easy!!!
