Tunnel fix
luvsno
Mississauga Ontario
My 98 srx had been hit in the back last year. Shortened by about 6 inches
up to the rear most skid mounting plate. I would like to straighten it out but am having difficulty finding out where is stong enough to brace against for a small porta power to straighten it. Has anyone done it and are there any spec for measurements I can compare to. I would say there are 3-4 ripples in the tunnel top and 2 on sides. It doesn't have to look perfect but I would like to ride it. Thanks for any help at all!! luvsno
Might be easyer to cut it out and rivet a new extension back on they are only like 100.00 and will look like new. If it's rippled down to the running boards you can fix that after you get the top cut off. Doug
