deekersrx700
Will 10 tooth drivers work on an SRX?
yamaholic22
not with a track of any profile except maybe asphalt. Anything else would require a drop and roll of the chaincase.
deekersrx700
Ok thanks yamaholic.
You can fit up to roughly a 1" track under it with 10" front drivers, but there will be no space. We run with 10" front drivers on the grass with a .5" speed track and studs that are .75" above the lug yet.
deekersrx700
Allen, so with the stock track the 10 tooth drivers will work? I have 1.175 studs in it, just looking for more speed.
Deek
Deek
yamaholic22
no it definately will not fit with the stock track and 1.175 studs. I think Allen was saying that it would fit with a 1" track, but not with studs.
You might at most be able to get 1.125-1.25" total height in but if you run studs I guarantee it will slap the cooler on deceleration when you touch the brakes, been there, never put a hole in one yet, but have rubbed the fins completely off!
deekersrx700
thanks allen and yamaholic
