fhs
89A10 weights, green white green primary spring and 47/43 helix?
A friend has suggested this. What do you think?
To be used for mostly trail riding on a 99 srx 700, m-10 to be installed.
yamaholic22
should work good, just make sure you clutch it to pull 8100 to 8200 out of the hole, creeping up to 83-8400 on top end.
it will work well.I woulkd stick with stock weight if your going to mostly trail ride.
89a-10,s are good lake running weight but a little lazy for backshift.
fhs
drivers/gears and weights
Should I be changing the drivers or gearing with the above setup. Going in stock SRX700 with bender can. Would 8dn-20 weights be a better choice than the 89A10 weights?
yamaholic22
depends what you want to do. DN20s are definately a better all around weight, they backshift much better and still have an awesome upshift, but i think the 89A's upshift a little harder, but they don't backshift as well. For an all around good setup with DN's are better, for lake racing the 89's are probably a little better.
Styles211
FHS,
I wouldn't install that M10 with that setup, it will ride too smooth and slow you down. You should sell that M10 to one of your friends!!
HA HA
Styles
HA HA
Styles
