Clutch Work Questions
dnale
South Lyon, Michigan
Ok, I feel like I can't bother Larry at North Country Yamaha any more.
I got new washers for both the weight and the rollers. One set of washers is white and the other set is black. Which washers go where?
Also, I got new weights and rivets. Now I need to install the rivets. How? I know that sounds simple, but do I just use a bfh and pound on them? How much is enough?
Thanks.
Doug
white washers on weight pins and black on rollers.......i usually use a round head hammer and the base is my workbench......i pound until the rivets will not move side to side and are snug in place.......make sure the rivet heads are the same way so taking them out is not a problem.....pound the other side of the rivet where the head is .....good luck
