sway bar spacers
mattmichyam
Brighton, MI
I am in the process of long traveing a 2000 srx with longer front shocks. I have the radius rods and tie rods. Now I realize I need sway bar spacers or a new sway bar. Anybody know if I could make spacers or where i could buy some. Or even a pick of the spacer would help me greatly.
Thank you,
Matt
Matt,
not sure if anybody makes a spacer,
but i can selly you a new sway bar from a 2000 SXR pretty cheap, and they are pretty easy to put in.
$25.00 plus shipping.
if you know or can weld cut the little bar shorter between the bushings and weld one of them a little offset to take up the width differance and a washer behind itwhenyou bolt it to the trailing arm .doing this keeps the link close to straight up and down.put them in a wet rag when you weld or they burn the rubber out as well.
I ordered some from Maxx Perf. They used to sell the wide kit for SRX's. They still had some around. Thanks for the help everybody. When I get it transfored I will post some pics.
Matt
