viper clutch alignment
you really should loosen all of them if you are going to be aligning the clutches. Do you have an adjustable engine torque stop? Definately worth the money, keeps the alignment and center to center in check much better. If you don't have one, I usually set them up with a little bit longer center to center than recommended, along with the engine turned slightly clockwise from perfect alignment with the idea that under hard acceleration, the play in the rubber mounts will pull the engine into close to perfect alignment and center to center. Little tricks you learn along the way, but a torque stop takes out the guesswork.
There are three different points you can loosen the motor mounts in front(theres a bracket that bolts to the motor,the rubber mount that bolts to that and another bracket that bolts to the frame.I understand the motor mounts must all be loose,im just asking exactly where do i loosen them so i can move the motor around.
oh sorry about that, i read it wrong. Yea you loosen them where they bolt to the frame.
Well i got the sled pro alignment tool in and ran out to the garage to see how far my clutches were off(center to center and offset).I took the secondary off put the tool on and........................their perfect!! I know i should be happy but now i have this 130.00 tool i bought for no reason.Oh well,it will come in handy some day.
