Nitrous on SRX 700, it is worth it ???
jig-a-boo/srx
Has anyone tried Nitrous on a SRX700, and if so, how was the performance.
Grass drag times and MPH in 500 ft
Ice drag times and MPH in 1000 ft
Ice drag speed runs
the MPH in 500 feet is not of importance. its about how fast you get there, not how fast your going when you get there. you need to watch your tach RPM's if anything.. a STOCK srx should get there in about 6 seconds or slightly less dont know about NOS
did boondockers on srx 700 good for about 5 to 6 sleds in 500' when set up right . stock to stock both sleds where about the same.
SRX on Nitrous
How was it dialing in everything, lots of weight on the primary to prevent over revving????. Was it consistent????. For $750 I could add 15 hp to 20 hp per cylinder, if I can get that to the track and hook-up it should perform well. What size jets and pilots did you run????
