Stephan
- Jun 29, 2005
Hello Turk !
can you tell me what you think about this clutch set-up ??
( CPR TRIPLE PIPES, SPEEDWREX, HEAD,12/1,CARBONTECH REED VALVE,
hEEL CLICKER 2 SPEEDS, < RED PRIMARY SPRING, 4.8 GRAMS SHOULDER,
3.1 GRAMS CENTER, , THE SECONDARY CLUTCH IS A ADVENT-EDGE R-3
ROLLER CLUTCH 35/31 CAM, WITH GRAY SECONDARY SPRING FROM ADVENT-EDGES WITH ONE CHIM ON THE SECONDARY, )
I never try this set-up, this is a summer project, and ADVENT-EDGE MOTORSPORT ( WERE I BUY ALL THOSE ITEMS ) give me this set-up
but they forget to tell me at what position the secondary spring should be.
and what is the location were a should put that shim ?
I know that you have experience with R-3 ROLLER CLUTCH,
MAYBE YOU CAN HELP ME !!!
I also have 120 studs.
anny one have similar modification that can help me ????
Rick from Advant-edge is usually pretty close with his set ups but I like to run a lot more secondary twist then he recommends. Start off with secondary at 60 degree wrap & see where rpm,s are at. I needed to tighten my secondary a lot running his steeper stuff cus in powder snow the sled just died. That 35/31 is pretty shallow & pretty close to a 45/41 dalton type helix.
