ReaperSRX
Can someone tell me what each code (flash) means, i only seeing 2 flashes after start up, sled runs fine..........Reaper
ikeever
- Sep 10, 2003
i'm prett sure they are in the tech page
let me know if you can't find them
i have a book
i have a book
ReaperSRX
Found them but?
Ok found the chart on tech pages, but it shows three flashes means everything ok, but nothing for 2 flashes, everthing else looks like the patern would repeat constanly, am i missing something here.........Reaper
ReaperSRX
Charts are for 2001 and up, does anybody have or know the codes for 2000 SRX 700...............Reaper
ikeever
- Sep 10, 2003
should be the same? are you sure it is only flashing twice? and is it only when you start it up?
ReaperSRX
I am almost positive 2 flashes when i start up, when i first noticed i paid more attention to gauges for over 30mins and it never came on again, but i double check this weekend.........Reaper
fourbarrel
VIP Lifetime Member
Fault codes
On my 98 the light flashes as soon as the engine fires up so unless you are watching closely you may be missing the first flash and only seeing the second 2.I went through the same anxiety for a while until I watched the light more closely.Try that and see what happens,I cant say as Ive ever heard of a 2 flash code.
