mulderdad
I did a compression test on wifes 94 vmax600.
Got 118 and 116.
Does this sound ok?
5700kms.
thanks,
mul
Got 118 and 116.
Does this sound ok?
5700kms.
thanks,
mul
mulderdad
anyone?
if your still woundering thats not bad, mabie a little higher 120-135 how many miles??
mulderdad
I bought a better gauge and did it again.
Got 125 and 126. Much better.
5700k's=approx 3500miles.
mul
mul
Yup....thats better.
Zack1978
- Dec 12, 2005
Bump of an old thread....
So how do I do a compression test? Should both spark plugs be removed, and the compression tester in one cyl at a time I assume? Should one plug remain in the sled while the other cyl is being tested? Should the engine be warm or cold when doing the test?
Thanks,
Zack
Thanks,
Zack
Rustman
I do it plugs out, cold engine, kill switch on, one cylinder at a time, and about 5 good pulls.
Throttle Junkie35
I believe you meant to say ''kill switch off''.I do it plugs out, cold engine, kill switch on, one cylinder at a time, and about 5 good pulls.
Zack1978
- Dec 12, 2005
So the pull starter is the best way as opposed to using the electric starter?
Thanks,
Zack
Thanks,
Zack
Throttle Junkie35
It doesnt matter. Just crank or pull until the gauge stops showing an increase in pressure.
Rustman
I guess, semantics I suppose. Is it in the "off" position for motor to run or the "on" position for motor to run. I would think kill switch on would mean it's activated and prevent the motor from running. In any case push the button down to test compression. Not sure about electric start, never had a sled with that luxury.
Throttle Junkie35
Lol, I guess is the glass malf empty or half full?? I never really thought about it any other way. Makes sense either way.
