Brake line
herb
Saskatchewan
Is the brake line on a 02 viper the same as other newer yamaha's? There is a line on ebay for all newer yamaha's except rx1 and viper.Are they talking about the new viper with new style controles?I thought they were all the same.
i have a o2 viper used break line in good shape i will sell you if you need one. i just put risers on and it was to short
depending on how high you are going the 05 mtn viper cables are the longest ones. if you go this route make sure to get an extra one of the hollow bolts and brass washers because the ends of the 05 viper cable is two banjo ends not one banjo and one threaded connector. then you need to unscrew the female connector on the brake cylinder and it will hookup fine.
