Rear shock length
ecopter
Staunton, Il
I need to replace the non-rebuildable shock in the '02 Vmax. Will an '04 Venture rear shock be an exact replacement, or is it to big to fit?
Thanks,
Jon
It will fit fine, the install length is just a few mm longer, but there is plenty of travel to allow for that.
The spring rate will be a bit heavier though. and result in a stiffer ride.
If it were me I would pick a used Viper shock instead as it is rebuildable, and the springs are changeable.
