1989 Yamaha Bravo 250
freezie
im adding a primer to this sled and im wondering where i tie it into the carb? Any ideas ?
basically i want to make it easier to start for my 10 yr old.
thanks !!
Primer
I have only done 1 primer, I hink you only connect it into the fuel line. The packge should have an installation diagram.
thanks !!
i wish it did have a diagram, but nope.Finding info on this is like pulling teeth....
primer
I installed one on my Elan. I just "T"ed into the fuel supply line and then put a nipple on the intake manifold to accept the fuel coming from the primer. I found that not all primers are created equal. The cheap ones are junk. I found that genuine Ski Doo pumps actually work.
I put a primer on my kids Bravo 250. If you did not get a small primer nipple with the kit, then run back to the store and order one up. They are made of Brass. Drill the carb and press it in... make sure the fit is good and tight.
As for fuel supply, just "T" into the main feed somewhere between the pump and the carb. Primer line goes from the "T" to the primer plunger, then to the nipple. Couple of squirsts and you should be up and running. I mounted the plunger in right where the choke was, been a good way to go for us. I can get pics if you need them.
