Gram Scale
nailsandrails
Northern, IL
I want to get a gram scale, but don't want to spend 100 bucks. What's the cheapest scale out there that will still do an accurate job? I'm weighing heelclicker weights.
:D:DP ya sure ya are. we know what your up to Smokey .
are the calibration weights really necessary with these scales on ebay? You have to buy them seperately, so that made me wonder...
calibration
Just use a dollar bill. It weights exactly 1 gram. That will tell you if it's off or not. In all reality you should calibrate it with a heavier weight cell, but a dollar will give you a quick check. Hope this helps. Chad.
P.S. I know someone is thinking it so I'll say it. YES a twenty dollar bill still only weights 1 gram. LOL :o|
just go to your local hardware store and weigh a few things(they usually have a really good digital scale) till you find something around 50 grams, buy it then keep that as a calibration weight for yourself. just make sure you put up the weight afterwards so it dont get damaged and loose weight.
you got a smokin deal on that scale.
