sxviper32
monkey, your missing the point. its not a sleeper. a 500 twin and a piped 700 are so distinguishable its not even funny. and even if you claim its for insurance, thats ridiculous cuz if your anything would happen to your sled you would only be covered a 500 not your 700 that cost more to buy and build. neither way, its really a hopeless idea...
2000sxr600
familyman said:Cant you put sx700 cylinders on a sx600r?? I would guess that you could. There both non-power valves. You are basically slightly big boring it to a 700.
Another option take your cylinders in and have a machine shop sleeve them for a sx700 cylinder...buy pistons and rejet. I might be wrong but seams about the same. (most shops will charge $110 to sleeve, plus $80 per piston = under or right at $400 with gaskets!)
As for the srx bulkhead to a sxr. If its a tripple they are the same...are they not. But once you get a power valve motor you need the electrical and carbs to go with it also...right? This is my useless knowledge...take it or leave it.
i really like this idea....any one ever try it?
yamaholic22
yes a handful of 600's have been turned into 7's, really not very difficult at all. Just gotta know what you have to do, and that isn't much. Cylinders, pistons, cdi, carbs (33mm instead of 31mm), and clutching.
