snowjunkysrx
- Oct 27, 2005
Just wondered if anyone had some ideas that could help me. I have a sxr600 and I find myslef having to change my hyfax about every 400 miles. Is this a normal thing with sxr's?? Is there anything I can do to prevent my slides from wearing out so fast? I have already tried loosening the track and saw no significant changes. any ideas or solutions?????
ekimsx600
I've had the same ones on my sxr for over 1500km. I use polaris idlers at the bend (all 4) and have my limiter straps pulled up so there is 25mm of thread above the nut.
A tip I read here a few years ago was to heat them up real good and then quickly cool them down again,( something like heating it up with a propane torch and then splashing some water on it) doing this would harden the surface of the hyfax, making it last longer.
I got about 2000 miles off my last set. sounds to me like you need to pull up the limiter straps a bit or find more snow...
Also like stated above, the warm cold thing, but i just put them on then run them down a road with little snow to warm em up then hit some deep stuff to cool them off.
yamaholic22
hoffam19 said:I got about 2000 miles off my last set. sounds to me like you need to pull up the limiter straps a bit or find more snow...
Do as he said to "cure" the polymers. I have the FACTORY set on my '01 SX 700R with 5,600 miles on it. Guess i must be doing something right.
snowjunkysrx
- Oct 27, 2005
thanks a lot for the imput. I think i'll adjust the limiter strap and see what happens.
I run my sled up the field and back in the summer. Come back and hit it with cold water. It hardens them and last longer! Good luck.
daytripper
- Nov 4, 2003
get the graphite hyfax from yamaha and leave the track loose.
