thundershift kit (installing)
Check for side to side play when the weight is on the pin & mounted in the clutch. There should be very little side to side play.
turk. what im trying to explain is the bolt itself not the plastic washers that go on the inside. i hope its not a big deal because i didnt use any. thanks for the reply. i used 4 of those plastic washers on the flat side,and 2 on the other side. except for one weight. i had to use the ones that came out of the bender clutch kit witch were thicker so i used 3 on the flat side and 2 on the other side.
If there is no play anywhere & the pin is solidly in place you will be fine.
