What does the clip/shim thing all about on the jets in the carbs? Does the different positions richen or lean out the system with small increments then the jet sizes? Thanks
Mtnviper
The clip/needle adjustment is for 1/4 to 3/4 throttle tuning. Jet size effect's 3/4 to full throttle. Rising the clip drops the needle, leaning out the mixture. Lowering the clip will raise the needle and rich'n the mixture. The little white shims are for "1/2 clip" adjustments for fine tuning. They can be both on top or bottom of the clip. Or you can have one on each side of the clip.
This mid-range tuning can be helpfull when trying to correct a lean bog or rich burble condition.
Awesome thanks!!
