midrange loading up on tight trails...
sockeyerun
Test Dummy
Anchorage,AK
02'MM, - 1 layer, bored silencer, reed spacers. riding through tight trails I'm getting the burble(loading up) I'm hearing about (between 5000-6000rpm). My jetting and settings are all stock for 330-1600 ft except, I'm having to run my pilots at 1 3/4 instead of 1 1/2. I have read that dropping the needles down, by moving both washers on top of clip should clear this up. Is this correct? My plugs look fine....Thanks
