Cory_090
If i just put clutch weights on my stock clutch would it make much difference ? I noticed how cheap they are and i was wondering if this is a cheaper way to gain throttle response ?
nailsandrails
The weights are added to get your sled to run in it's peak RPM range. You would need to know where it is running in order to know if you needed to add or remove weight.
Cory_090
how can I find this out ?
yamaholic22
where does your sled rev on a wide open run, right at take off, in the midrange, and on top end? You can't just go changing weights and expect to make gains.
