T terret725 New member Joined Sep 29, 2005 Messages 972 Location berkshire mass Nov 2, 2005 #1 whats the best hi temp paint to repaint my pipe with?
kysledneck New member Joined Apr 19, 2005 Messages 674 Age 58 Location Georgetown KY Nov 2, 2005 #2 I used a 1200 degree paint Plasti coat I believe! it said aluminum but it ended up very shiny! stayes on there too! wire wheeled it then painted. Attachments IMG_2600.JPG 79.5 KB · Views: 15
T terret725 New member Joined Sep 29, 2005 Messages 972 Location berkshire mass Nov 2, 2005 #3 Thanks
yamaholic22 Active member Joined Oct 23, 2003 Messages 5,276 Location Iowa Nov 2, 2005 #4 1200 degree paint will eventually start to fade and burn off up by the manifold, get 1500 degree paint if you can.
sxviper32 New member Joined Feb 9, 2004 Messages 1,307 Age 39 Location Valparaiso, Indiana Nov 3, 2005 #5 VHT Flameproof paint comes in colors. if you drop the colors, (1200 degrees) you can go up to the next which i believe is the 1500 paint but its only in black i think.
